I’ve used CSS code sinppet to add to the margin between lines and lists. But it only works in preview mode. Here is the code.
.CodeMirror pre.CodeMirror-line {
padding-top: 6px;
padding-bottom: 6px;
li{
padding-top: 6px;
And I’ve already add “style setting” plugin to adjsut the line height.
I want to make the edit mode and preview mode appear to be same. I perfer wider space between headers and paragraphs, lists and paragraphs, paragrahs and paragraphs.
Do the classes given in this answer by @anon12638239 help? (Found by searching edit mode css.)
Does this work?
/* Editor View */
.HyperMD-header.HyperMD-header-3 {
text-align: center;
/* Reading View */
.cm-header-3, .markdown-preview-view h3 {
text-align: center;
Angel
Thank you so much! It works!
Here are codes and results:
.HyperMD-header.HyperMD-header-1 {
line-height: 2.5; /* It works */
padding-top: 8px; /* it doesn't work */
padding-bottom: 8px;
system
Closed
September 1, 2022, 9:08am
4
