This work normal on me ._. (My Obsidian is 0.12.15, installer 0.12.15)
/* Reduce indentation in bullet lists */
ol {
padding-inline-start: 18px;
ul {
list-style-type: disc;
/* Long bullet list: connect the same levels of bullets with vertical "lines" */
.cm-hmd-list-indent .cm-tab, ul ul { position: relative; }
.cm-hmd-list-indent .cm-tab::before, ul ul::before {
content:'';
border-left: 1px solid rgba(0, 122, 255, 0.25);
position: absolute;
.cm-hmd-list-indent .cm-tab::before { left: 0; top: -5px; bottom: -4px;
ul ul::before { left: -11px; top: 0; bottom: 0; /* change "left:" value for align of vert. line */
/* Edit mode unordered list dash rendered as dot for WYSIWYG */
/* I prefer "Turn -lists into bullets as you type as per Typora */
/* Unordered lists: turn into bullets as you type, as per Typora */
```css
span.cm-formatting-list-ul {
visibility: hidden !important;
span.cm-formatting-list-ul:after {
content: '• '; /* ITS theme; for Blue Topaz */
margin-left: -12px;
color: var(--accent); /* ITS theme; for Blue Topaz --text-normal */
visibility: visible !important;
