How to add a note shortcut to the homescreen on Android
I know there has been a feature request for this and you replied to it
BUT, I’d personally benefit from a button. The flow is not complicated, but for frequent use, it gets old real fast. I’d very much prefer a button.
Do you guys know if there is an active feature request for this? I haven’t found any, but wanted to check, just in case, so I don’t post something redundant. Thanks!
@Joschua this works beautifully, thank you! When I’m done with my note, it leaves Obsidian open. Is there a way to close Obsidian, returning me to my home screen when the task is complete?
This is sooooooooo simple! Thank you!!!
Note: It looks like today Obsidian does have a native Copy Obsidian URL command which works better than the Advanced URI plugin.
I’ve not been able to create a second shortcut with Shortcut Maker for some reason, but the first one works with the settings as per @homostellaris 's screenshot and the URL from Obsidian directly.
+1 to widgets
Bought a new phone so I thought I’d check in on the status of this. Can’t believe using Tasker or Automate is still the only solution to link to an article!
