Hello
I synch a folder with my vault inside.
and when i push it in my github repo i don’t get my wikilinks.
Do you know how can i get my wikilink and dataview in a github repo ?
Hello
Github’s markdown doesn’t support wikilinks, only markdown links. Dataview also doesn’t work in Github because it is an Obsidian plugin.
Even though they won’t work in Github, you will still be able to interact with them as wikilinks and dataview queries whenever you view them with Obsidian.
And is it possible to keep the relationship between the links (dataview and wikilinks) on an obsidian vault and then convert it to a static site with nextjs, hugo or gatsby?
