Hey everyone,
I wrote a post on a little hack I use to get accurate GPS location information in Obsidian, without resorting to 3rd party apps. Not sure if a similar solution has been shared before, but I thought that people might find it useful.
Hey everyone,
Some more information scent for anyone curious:
This is specifically for iOS/OS X
The gist of it is to create a Shortcut, which will run periodically (or on any other trigger you like) on a device that has location capabilities, and insert the location information directly in your vault, in a note, in
FrontMatterformat.
- I sync between my mobile and desktop app through iCloud
- Not sure if it would work with other sync solutions - haven’t tried it.
Sure. Shortcuts can save text to files outside of iCloud, and Obsidian can use other sync systems.
