How do you manage recurring projects (actions with more than one task)?
Let’s say you have a list of open tasks:
## To-Do's
- [ ] Task1 πŸ” every 3 months ⏳ 2023-04-15
- [x] Task1 πŸ” every 3 months ⏳ 2023-01-15 βœ… 2023-01-28
- [x] Task2 βœ… 2023-01-28
- [ ] [[Recurring Project1]]⏳ 2023-01-05 πŸ” every year
The content of the Recurring Project1 note look’s like this:
## To-Do's
- [x] Task1 of Project1 βœ… 2023-01-21
- [ ] Task2 of Project1
- [ ] Task3 of Project1
When I check off all the tasks of Project1 and also check of the β€œmain” to-do (the Recurring Project1 task) afterwards, the new scheduled date for the task is set,
## To-Do's
- [ ] [[Recurring Project1]]⏳ 2024-01-05 πŸ” every year
- [x] [[Recurring Project1]]⏳ 2023-01-05 πŸ” every year βœ… 2023-02-03
which is fine, but the according β€œsub-tasks” are still all checked off of course.
How is your workflow for recurring projects and their tasks?
How do you manage actions which require more than a single action and that are also recurring in any way?
Many thanks for all your input and ideas!
montharon
I’m not really into recurring tasks, but two ideas spring into mind:
  1. Have a reminder on the recurring project to add tasks to workflow. In other words, the recurring task is to insert a template with all of the tasks related to the recurring project
  2. How would it work if your main task is recurring, and all the other tasks are sub-tasks of that recurring task? Would tasks then reset the subtasks for the new incantation of the task? Update: No, it won’t…
Thanks for your idea @holroy!!
How do you link the tasks to the recurring template?
Does that mean that each recurring β€œtask” links to a different note with differen tasks?
Hmmm :thinking:
Many thanks!
montharon
