How do I use Enhancing Export/Better BibTex Zotero citations in group libraries?
Exporting references from Zotero group libraries to .docx
I’m following the instructions posted by FeralFlora here and instructions here for exporting Zotero pandoc citations using Enhancing Export/Better BibTex with the zotero.lua filter to live Zotero citations in a .docx. I’m trying to cite works stored in a shared group library, which show up fine in Obsidian in reading mode.
I’ve copied the document properties listed on the above-linked pages, replacing under the “library:” property with the name of the group library, “Collaborative_research”, without brackets. I’ve tried with and without quotation marks, and I removed a space from the actual group name in case that was causing problems. Yet the .docx document that gets outputted only has live Zotero citations for references in “My Library,” with the original md text for any references I try to cite from my group libraries, suggesting that it can’t find them.
I haven’t found any documentation or forum threads explaining anything to do to help Enhancing Export locate Zotero group libraries.
I’ve located several threads on how to use the zotero.lua filter to generate live links. I’ve searched for forums that talk specifically about problems with group libraries but haven’t found any.
I’m probably overlooking something basic. Any idea what I might be doing wrong?
Thanks!
