You did nothing wrong. The feature you are looking for simply does not exist yet. Bases can decide the properties and the folder of a new note, but not its filename or content. People have been asking for this in a feature request called “Bases: New With Template (for ‘New’ Button)” since July 2025, but it is still not implemented.
The “Unique note creator” plugin did not help because it is a separate command with its own hotkey. The + button inside a base does not use it. Remapping Ctrl+N will not change how that button works.
Here is a workaround that works today (@Azmonial described this in that thread and it is still valid):
Filter the base to a specific folder, so the + button creates the note there.
In Templater settings, enable “Trigger Templater on new file creation” and set it to Folder mode.
Add a folder template mapping that connects this folder to a template containing:
There are three important details that determine if this will work. I spent some time figuring them out:
tp.file.rename will crash if the name contains \, /, or :. So a timestamp format with colons like HH:mm will fail. HHmm works fine.
Folder templates always use the deepest matching rule. A mapping for your specific base folder will win over a more general rule above it. A rule on / works as a fallback for everything else.
It still triggers even though Bases already pre-fills the properties. The trigger only runs on an “empty” file, but it actually checks the content below the frontmatter. So the properties added by your base do not break the Templater script. This is very good to know.
However, it is worth stepping back and looking at this differently. A base is just a query, not a container. The + button is only a shortcut, not the required way to add things. You can create the note however you normally do, for example with the Unique note creator, a Templater hotkey, or QuickAdd. As long as the note lands in the right folder or has the correct properties, it will show up in your base automatically. Once you stop treating the + button as the only way to add notes, this missing feature is no longer a problem.
