How do I insert a tag that has multiple words with spaces in between?
You can’t use spaces for tags. You could use dashes instead of spaces or just not use spaces and have the words one after another.
I am not sure what your use case is, but nested tags are also an option.
Good luck!
In support of what @I-d-as says, this might be useful:
