I wonder how i can get this Graph view, that’s only in the upper right corner, and shoes all the conections to the open Noten.
I’m sure that’s have to be easy, but I cant find a way to get it: So pls helb me.
Thanks
Thanks
The command is “Open Local Graph”. You can run it with the command palette. Or you can find it in the menu for the note.
In your theme, it’s a button that looks like three dots at the bottom of your sliding panes.
