How do I CSS only "Text Labels for Primary Navigation" from Minimal Theme Settings plugin
I’m using Ultra Lobster Theme which I prefer more than minimal theme. I like the out of the box beauty. But I miss tabs with titles in the right sidebar from minimal.
I tried using the minimal theme settings plugin but it didn’t work. :man_shrugging:
So my only option is to try using css snippets. But I just can’t seem to figure it out. I’ve messed with the inspector and no matter how I manipulate the width or padding. The tab doesn’t change.
The tab header container doesn’t show how it’s minimizing the tabs. Why can’t I make the tab take the full available space?
Hey! Did you find a solution? :thinking:
From the minimal source code:
/* MIT License | Copyright (c) Stephan Ango (@kepano)
Labeled Nav snippet for Obsidian
author: @kepano
version: 2.0.0
Support my work:
https://github.com/sponsors/kepano
.labeled-nav.mod-windows,
.labeled-nav.is-fullscreen:not(.colorful-frame) {
  --labeled-nav-top-margin: 0; }
.labeled-nav {
  --labeled-nav-top-margin: var(--header-height);
  /* refactor this using a new variable for border above labeled nav
  in different conditions e.g. OSes and colorful frame */ }
  .labeled-nav.is-translucent .mod-left-split .mod-top .workspace-tab-header-container .workspace-tab-header-container-inner {
    background-color: transparent; }
  .labeled-nav.is-hidden-frameless:not(.is-fullscreen) .mod-left-split .workspace-tabs.mod-top-left-space .workspace-tab-header-container {
    padding-left: 0; }
  .labeled-nav.mod-macos .mod-left-split .mod-top .workspace-tab-header-container:before, .labeled-nav.mod-macos.is-hidden-frameless:not(.is-fullscreen) .mod-left-split .mod-top .workspace-tab-header-container:before {
    -webkit-app-region: drag;
    position: absolute;
    width: calc(100% - var(--divider-width));
    height: calc(var(--header-height) - var(--tab-outline-width));
    border-bottom: 0px solid var(--tab-outline-color); }
  .labeled-nav.mod-macos.is-hidden-frameless:not(.is-fullscreen) .workspace-ribbon.mod-left:not(.is-collapsed) {
    border: none;
    --tab-outline-width: 0px; }
  .labeled-nav:not(.is-hidden-frameless) .mod-left-split .mod-top .workspace-tab-header-container:before, .labeled-nav.mod-macos:not(.hider-ribbon) .mod-left-split .mod-top .workspace-tab-header-container:before, .labeled-nav.colorful-frame.is-hidden-frameless:not(.is-fullscreen) .mod-left-split .mod-top .workspace-tab-header-container:before {
    border-bottom: var(--tab-outline-width) solid var(--tab-outline-color); }
  .labeled-nav:not(.is-hidden-frameless) .workspace-ribbon.mod-left:not(.is-collapsed), .labeled-nav.mod-macos:not(.hider-ribbon) .workspace-ribbon.mod-left:not(.is-collapsed), .labeled-nav.colorful-frame.is-hidden-frameless:not(.is-fullscreen) .workspace-ribbon.mod-left:not(.is-collapsed) {
    --tab-outline-width: 1px; }
  .labeled-nav:not(.is-hidden-frameless) .mod-left-split .mod-top .workspace-tab-header-container:before {
    position: absolute;
    top: 0;
    content: " "; }
  .labeled-nav.hider-ribbon.mod-macos.is-hidden-frameless:not(.is-fullscreen):not(.is-popout-window) .mod-left-split:not(.is-sidedock-collapsed) .workspace-tabs.mod-top-left-space .workspace-tab-header-container {
    padding-left: 0; }
  .labeled-nav .mod-left-split .mod-top .workspace-tab-header-spacer {
    display: none; }
  .labeled-nav .mod-left-split .mod-top .workspace-tab-header-inner-title {
    display: inline-block;
    font-weight: 500;
    font-size: var(--font-adaptive-smaller); }
  .labeled-nav .mod-left-split .mod-top .workspace-tab-header-container {
    position: relative;
    flex-direction: column-reverse !important;
    height: auto;
    width: 100%; }
    .labeled-nav .mod-left-split .mod-top .workspace-tab-header-container .sidebar-toggle-button.mod-left {
      position: absolute;
      justify-content: flex-end;
      padding-right: var(--size-4-2);
      top: 0;
      right: 0; }
    .labeled-nav .mod-left-split .mod-top .workspace-tab-header-container .workspace-tab-header-container-inner {
      padding: var(--size-4-2) var(--size-4-2);
      margin-top: var(--labeled-nav-top-margin);
      flex-direction: column !important;
      background-color: var(--background-secondary); }
    .labeled-nav .mod-left-split .mod-top .workspace-tab-header-container .workspace-tab-container-inner {
      flex-grow: 1;
      gap: 0;
      padding: var(--size-4-2) var(--size-4-3); }
  .labeled-nav .mod-left-split .mod-top .workspace-tab-header {
    --icon-color: var(--text-muted);
    --tab-text-color: var(--text-muted);
    --tab-text-color-focused: var(--text-muted);
    padding: 0;
    margin-bottom: 2px;
    border: none;
    height: auto; }
    .labeled-nav .mod-left-split .mod-top .workspace-tab-header.is-active:not(:hover) {
    .labeled-nav .mod-left-split .mod-top .workspace-tab-header.is-active, .labeled-nav .mod-left-split .mod-top .workspace-tab-header:hover {
      opacity: 1;
      --tab-text-color-active: var(--text-normal);
      --tab-text-color-focused: var(--text-normal);
      --tab-text-color-focused-active: var(--text-normal);
      --tab-text-color-focused-active-current: var(--text-normal);
      --icon-color: var(--text-normal); }
    .labeled-nav .mod-left-split .mod-top .workspace-tab-header .workspace-tab-header-inner {
      gap: var(--size-2-3);
      padding: var(--size-4-1) var(--size-4-2);
      box-shadow: none;
      border: none; }
  .labeled-nav .mod-left-split .mod-top .workspace-tab-header.has-active-menu:hover,
  .labeled-nav .mod-left-split .mod-top .workspace-tab-header.is-active:hover {
  .labeled-nav .mod-left-split .mod-top .workspace-tab-header.is-active:hover .workspace-tab-header-inner,
  .labeled-nav .mod-left-split .mod-top .workspace-tab-header:not(.is-active):hover .workspace-tab-header-inner {
    background-color: var(--nav-item-background-hover); }
  .labeled-nav .mod-left-split .mod-top .workspace-tab-header:hover .workspace-tab-header-inner-icon,
  .labeled-nav .mod-left-split .mod-top .workspace-tab-header.is-active .workspace-tab-header-inner-icon {
    color: var(--icon-color-active); }
    border: none;
    padding: 0; }
/* Links and underline handling*/
body:not(.links-int-on) {
  --link-decoration: none; }
body:not(.links-ext-on) {
  --link-external-decoration: none; }
body:not(.sidebar-color) .mod-right-split {
  --background-secondary: var(--background-primary); }
  body:not(.sidebar-color) .mod-right-split :not(.mod-top) .workspace-tab-header-container {
    --tab-container-background: var(--background-primary); }
I always came back to this thread while googling this question, so I thought I’d share my css snippet that’s working in Obsidian 1.12.7. It’s based on Minimal Theme, so 99% of the credit goes to kepano :slight_smile:
/* Labeled primary navigation for Obsidian default theme */
body {
  --labeled-nav-top-margin: var(--header-height, 40px);
  --labeled-nav-bg: var(--background-secondary);
  --labeled-nav-item-gap: var(--size-2-3);
  --labeled-nav-item-radius: var(--radius-s);
  --labeled-nav-item-padding-y: var(--size-4-1);
  --labeled-nav-item-padding-x: var(--size-4-2);
/* Windows usually still needs space for the toggle/header area */
body.mod-windows {
body.is-fullscreen {
/* Remove the default horizontal tab-strip spacer */
  display: none;
/* Keep the whole left sidebar/top-tab area on the normal sidebar background */
.mod-left-split .mod-top .workspace-tabs,
.mod-left-split .mod-top .workspace-tab-container,
.mod-left-split .mod-top .workspace-tab-header-container,
.mod-left-split .mod-top .workspace-tab-header-container-inner,
.mod-left-split .mod-top .workspace-leaf,
.mod-left-split .mod-top .workspace-leaf-content {
  background-color: var(--labeled-nav-bg);
/* Preserve the original snippet's core layout trick */
  position: relative;
  align-items: stretch;
  justify-content: flex-start;
  width: 100%;
  height: auto;
  min-height: 0;
  padding: 0;
  padding-inline-start: 0 !important;
  margin-inline-start: 0 !important;
  border: none;
/* Vertical primary navigation item list */
.mod-left-split .mod-top .workspace-tab-header-container-inner {
  display: flex;
  width: 100%;
  max-width: none;
  gap: 0;
  padding: var(--size-4-2);
  padding-inline-start: var(--size-4-2) !important;
  transform: none !important;
  left: 0 !important;
  overflow: visible;
/* Individual primary nav row */
  display: flex;
  width: 100%;
  max-width: none;
  min-height: var(--tab-height, 32px);
  height: auto;
  margin: 0 0 2px 0;
  padding: 0;
  border: none;
  background-color: transparent !important;
/* Icon + label row */
.mod-left-split .mod-top .workspace-tab-header-inner {
  display: flex;
  align-items: center;
  flex: 1 1 auto;
  width: 100%;
  min-width: 0;
  max-width: none;
  gap: var(--labeled-nav-item-gap);
  margin: 0;
  padding: var(--labeled-nav-item-padding-y) var(--labeled-nav-item-padding-x);
  border: none;
  border-radius: var(--labeled-nav-item-radius);
  box-shadow: none;
.mod-left-split .mod-top .workspace-tab-header-inner-icon {
  flex: 0 0 auto;
/* Show text labels only when expanded */
  .mod-top
  flex: 1 1 auto;
  min-width: 0;
  text-align: left;
  font-size: var(--font-ui-smaller);
  font-weight: 500;
  line-height: 1.4;
  overflow: hidden;
  text-overflow: ellipsis;
  white-space: nowrap;
/* Hide labels when collapsed */
.mod-left-split.is-sidedock-collapsed
  .mod-top
  display: none !important;
/* Active and hover text/icon color */
.mod-left-split .mod-top .workspace-tab-header:is(.is-active, :hover) {
  --tab-text-color: var(--text-normal);
/* Keep highlight limited to the label row */
.mod-left-split .mod-top .workspace-tab-header:hover .workspace-tab-header-inner {
  background-color: var(--nav-item-background-hover, var(--background-modifier-hover));
.mod-left-split .mod-top .workspace-tab-header.is-active .workspace-tab-header-inner {
  background-color: var(--nav-item-background-active, var(--background-modifier-active-hover));
/* Sidebar toggle button */
  position: absolute;
  top: 0;
  right: 0;
  z-index: 2;
