On the Default theme, if my indentation settings are such then how can I achieve consistency between the spacing in Edit mode and Preview?
The spacing in Preview mode seems to be four, whereas I would like it to be two as it is in the Edit mode.
I can’t give details, but you want a CSS snippet to change the margin or padding. If you’re lucky, someone may have posted one to the forum.
The indentation will be in a unit other than spaces (probably ems or pixels), but whatever it is, just use half the existing number.
