My list of templates is growing. I still use just a handful very frequently.
Allow me to set a direct template shortcut (CMD-1) for a specific template.
Give the templates weird names so that the most likely used ones shows up near the top, keyboard arrow navigation to find it.
I feel that this is like a snippet system.
In vim, I use Ultisnip for such actions. I prepend a ; before my snippet hotkeys, e.g. ;header<TAB>, so it won’t interfere with normal word auto-completion.
It would be cool to have a snippet system in obsidian.
I released a new plugin GitHub - Vinzent03/obsidian-hotkeys-for-templates. This should fix your problem.
That’s very nice!
Could it be smart and expand templater things also if that’s active? Like {{tp_title}} etc.
So you want to expand the functionality for the templater plugin?
I suppose I should send that there, right. Thanks!
No not needed. I already added support for Templater.
Created an account just to say thank you! This is exactly what I needed
