Hotkey for embedding selected text in another note
I often link or embed text snippets from my source notes into my own notes.
My current workflow feels pretty inefficient, so I’m looking for ways to streamline it.
What I’ve tried
Here’s my current process:
  1. I’m reading a source note and come across a passage I want to reference.
  2. I switch to my target note, create a wikilink with ^, and start searching for that passage.
  • Depending on the length of the source note, I often get many matching suggestions.
  • So I have to jump back to the source note, check the exact wording, then return to my note and try again to find the right block reference.
Idea for a smoother workflow
Ideally, I’d like to select a passage directly in the source note and embed it into another note via a hotkey — similar to Ctrl+C / Ctrl+V, but instead of copying the text, it would create a link or embed to that snippet
=> Do you have any suggestions how to accomplish that?
Hey! So @mgmeyers Created a great plugin a while back, I think it might be what you are looking for.
This is the .gif he added to demo his plugin:
Here’s the link to the Obsidian plugin
and here’s more info on his Github Page: GitHub - mgmeyers/obsidian-copy-block-link: Get links to blocks and headings from Obsidian's right click menu.
hope it helps
amacing!!! Thanks @santi!!!
Awesome glad I could help!
