Horizontal scrolling with mx Master not working
Have a mouse that has 2 scroll wheels (1 vertical and 1 horizontal) mine is the MX master 2
have a pdf file open I don’t know if it happens to other file types, but when the pdf file is fully loaded I some
Note: This bug is not consistant, sometimes it works to horizontally scroll but otherwise it just not working even closing and opening the file again it does not resolve the issue only restarting Obsidian does it, It is more of an annoying bug than a app breaking bug
The scroll issue is really inconsistant, in the beginning like first .5 sec I can scroll horizontally but than I can’t anymore, I can scroll with balk but not with my horizontal scrollwheel anymore than.
Horizontal scrolling in My zoomed in PDF Files in Obsidian
Not being able to scroll horizontally with my horizontal scroll wheel in a zoomed in PDF file.
Obsidian version: v1.7.7
Installer version: v1.7.7
Operating system: Windows 11 Home 10.0.22631
Language: nl
Plugins installed: 7
Plugins enabled: 7
1: Git v2.30.1
2: Latex Suite v1.9.7
3: Mind Map v1.1.0
4: Smart Connections v2.3.46
5: Advanced Tables v0.22.1
6: Image in Editor v2.2.6
7: Hotkeys++ v0.2.7
My english is not very well and I have dyslexia sorry for the many typo’s I will run this trugh chat gpt so I have a version with maybe better wording beneth this line.
Bug Report (Improved Wording)
Steps to Reproduce
  1. Use a mouse with two scroll wheels (e.g., MX Master 2, which has both vertical and horizontal scrolling).
  2. Open a PDF file in Obsidian. It is unclear if this issue happens with other file types, but it consistently appears once the PDF is fully loaded.
Note:
This bug is inconsistent. Sometimes horizontal scrolling works initially but then stops. Even reopening the file does not resolve the issue—only restarting Obsidian seems to fix it. While not app-breaking, it is a frustrating issue.
Troubleshooting
Yes, the troubleshooting guide was followed. The issue remains inconsistent. Horizontal scrolling briefly works for approximately 0.5 seconds before stopping. The scroll bar can still be dragged manually, but the horizontal scroll wheel ceases to function.
Expected Result
Smooth horizontal scrolling in zoomed-in PDF files using the horizontal scroll wheel.
Actual Result
Horizontal scrolling using the horizontal scroll wheel stops working after a brief moment in zoomed-in PDF files.
  • Obsidian version: v1.7.7
  • Installer version: v1.7.7
  • Operating system: Windows 11 Home 10.0.22631
  • Login status: Not logged in
  • Language: Dutch (nl)
  • Insider build toggle: Off
  • Live preview: On
  • Base theme: Adapt to system
  • Community theme: None
  • Snippets enabled: 0
  • Restricted mode: Off
  • Plugins installed: 7
    • Git v2.30.1
    • Latex Suite v1.9.7
    • Mind Map v1.1.0
    • Smart Connections v2.3.46
    • Advanced Tables v0.22.1
    • Image in Editor v2.2.6
    • Hotkeys++ v0.2.7
Recommendations:
  • Ensure all community plugins are updated to the latest versions.
  • Test the issue in the Sandbox Vault or disable community plugins to check if they are causing the problem.
Additional Information
Apologies for any initial typos; I have dyslexia and ran this report through ChatGPT to improve clarity. I hope this revised version makes the issue easier to understand.
