Hi all,
I’m currently using Obsidian 1.4.16, and I want to use dataviewjs to show all mp3 files that have been referenced using “#music” tag, as well as the progress bar so that I can directly play the music on the result of dataviewjs, I used the following code, it does show the bar, but the bar is not clickable, is there a way to solve it?
const files = app.vault.getMarkdownFiles();
const arr = files.map(async (file) => {
const content = await app.vault.cachedRead(file);
const lines = content.split("\n");
//stores the html elements for all mp3 that are referenced in text
let matchedSectionsOrLines = [];
lines.forEach((line) => {
// make sure that the mp3 is referenced using tag music
if (line.includes("#music")) {
//store the path for mp3 file
const audioRegex = /!\[\]\((.*?)\.mp3\)/;
const match = line.match(audioRegex);
if (match) {
const audioPath = match[1] + ".mp3";
matchedSectionsOrLines.push(`<audio controls><source src="${audioPath}" type="audio/mpeg"></audio>`);
return matchedSectionsOrLines;
Promise.all(arr).then(values => {
const flattenedValues = values.flat();
flattenedValues.forEach((text) => {
dv.paragraph(text);
The result of dataviewjs:
The text that referenced the mp3:
I know I can replace the HTML tag in the code with: <a href="${obsidianUri}">${audioPath}</a>
to show the URI of mp3 instead of the bar, but then I can’t play the music directly on the dataviewjs result.
Thank you very much for your help!
