High CPU load while idle
Hi yall, first post here.
im a “noob” to obsidian. been trying to figure it out for about a week. seems great on paper…
trying get myself out of MS OneNote, buuttt… lets save 4 different web clippers not working for another day
thou, this is not okay
i recently exported my onenote lib of 2844 .md files, around 37,300(images) files total with the images that came with it.
it takes obsidian about 3 minutes to launch. i can load steam and video game faster.
after 48 hours obsidian wont catch up. seems be stuck indexing the last ~300 files for day.
ive turned off index ocr & omniserch. it doesnt seem to make a difference on the performance hit im taking.
my desktop isn’t a rocket ship but its fairly powerful with and i7 6700 and 64g ram.
a text editor should impact it this much
any ideas of what is should look into first?
heres my debug info…
	Obsidian version: v1.5.12
	Installer version: v1.5.12
	Community theme: MagicUser v19.7.0
	Plugins installed: 54
	Plugins enabled: 42
		1: Importer v1.6.1
		2: Iconize v2.12.0
		3: Text Extractor v0.5.1
		4: Hotkey Helper v0.3.18
		5: Editor Syntax Highlight v0.1.3
		6: Recent Files v1.3.10
		7: Excel to Markdown Table v0.4.0
		8: Style Settings v1.0.8
		9: Export Image plugin v2.3.10
		10: Image Context Menus v1.7.0
		11: Customizable Menu v2.2.0
		12: Better Word Count v0.10.1
		13: Colored Text v1.0.0
		14: File Tree Alternative v2.5.7
		15: Extract url content v0.12.1
		16: Editing Toolbar v2.4.16
		17: Settings Search v1.3.10
		18: Image in Editor v2.2.6
		19: Templater v2.3.1
		20: Plugin Update Tracker v1.5.2
		21: Automatic Table Of Contents v1.3.2
		22: Auto Split v1.1.2
		23: Paste Link v1.0.1
		24: Table of Contents v0.2.0
		25: Slash Commander v0.2.16
		26: Reveal Active File Button v2.0.3
		27: markdown export v1.0.20
		28: File Info Panel v1.3
		29: Open vault in VSCode v1.2.2
		30: Favorite Note v1.0.4
		31: Prominent Bookmarked Files v2.0.2
		32: Time Ruler v2.3.0
		33: TagFolder v0.18.7
		34: Dataview v0.5.66
		35: CSV Table v1.2.0
		36: Commander v0.5.1
		37: Keyboard Analyzer v0.1.3
		38: Open Plugin Settings v1.3.2
		39: Local Images Plus v0.15.9
		40: Settings profiles v0.5.7
		41: Emoji Toolbar v0.4.1
		42: Omnisearch v1.22.2
So any final solution? Obsidian takes approx 25% of CPU when idle
Add the main.js file from here.
I don’t know about half of your plugins, so the rest needs divide and conquering.
Without your debug info, we can’t know.
Obsidian as the base app is not responsible.
I had a similar experience on my Windows machine with a different app where the fix turned out to be to disable hardware acceleration. I’ve seen other threads where hardware acceleration doesn’t play nice with some processors and driver configs (in my case I have a 9th gen i5-9400F).
I was not able to find any hardware acceleration configuration setting for Obsidian, so my somewhat clunky (but for me acceptable) work-around was to install and run Obsidian under WSL2 instead, where the processor spiking does not reproduce.
The hardware acceleration setting is in Settings > Appearance, in the “Advanced” section.
Hello!
Have the same trouble :expressionless:
What I found (just messed up personal experience):
  1. On any OS, if you have lots of files the memory load raises as the system is indexing and re-indexing them (what for if the diifference in search result speed is two seconds?). So on weaker PCs when you switch indexing off, the memory load immediatly becomes ok.
  2. I have no troubles with memory and CPU (acceleration, when memory is not enough?) on earlier Obsidian versions with small vaults.
  3. On any Obsidian version, when you have 10k+ long notes the Memory load raises
  4. When you browse the web with one pane by the Core web-viewer, say hello to about +20% Memory load.
  5. On newer versions the memory load is higher even when you have less than 10 notes. Not 10k+. just 10.
  6. Tech-geeks have PCs. The others have what they have. So the Tech Guys just don’t feel the difference with ther 64 gb Memory, newest CPU’s and other nice things. And that’s OK.
  7. The newer Chromium is, the more sources it takes. What are they wasted on, if nothing is changed for the user? Well, on Tech Geek options! How to switch them off? Go to… and do… and 100k+ things… and then it crashes.
  8. Obsidian is based on Chromium.
  9. There are non-obsidian related processes that load memory when obsidian is on (trying to index the files you are working on, parsing app activity data…)
So, what I think:
  1. Looks like the problem lies in Chromium core processes
  2. The older versions can potentially help. They are based on older Chromium (the newer Chromium is the more memory it takes…)
  3. The missing core plugins fuctionality can be added by community plugins on older versions
  4. The more heavy notes you have, the more memory load you experience.
If there was a way to switch off indexing processes and perform indexing only when you want…
There is no setting to switch indexing off. What indexing are you talking about?
Hello. This thread has become a catch-all for various problems.
Indexing should happen only once. When it happens, you do see a popup notification with a progress bar (v1.8.9+).
We are aware that there should be a relatively high (1 CPU core utilized) during and shortly after startup while Obsidian is reviewing of how your vault looks like (if anything has changed). The time it takes is proportional to the number of files in your vault.
If you experience high CPU usage in other circumstances you need to enable Restricted mode, use the default theme and restart Obsidian. If it happens again under these conditions, please open a bug report and follow the bug report template.
