Hi,
I’ve installed the hider plug in and it’s great. However, there are somethings I would like to do in the settings but the access has now gone.
I’ve tried the keyboard shortcut and that doesn’t work.
Is there a way I can locate the plug in so I can delete it manually. I don’t want to uninstall as I would have to spend a bit of time changing the settings to how I have them now.
I am using Obsidian on Mac.
Any suggestions?
