Help with WHERE in dataview not filtering as expected
I’m using Obsidian to capture meeting notes etc. I’ve created a frontmatter header that allows me to populate things like who I am meeting with, and various topic related items - I’m using YAML keys as much as possible to capture the primary purpose of the meeting - such who the company is that I meeting with e.g.
Date: 2023-03-17
Time: 14:00
Company: companyA,
Who:
- Paul
- John
- Ringo
- George
Guest:
- {Name: "Paul", Instrument: "Bass", Band: "Beatles"}
- {Name: "John", Instrument: "Piano", Band: "Beatles"}
When the meeting touches on adjacent topics, like other companies, I capture them in the body of the notes as inline keys for example [Company:: companyB].
When I create tasks, I also capture, as inline keys company names - as relevant.
My plan was to use MOC/Index pages to automatically group my meeting notes so I can give up on folders as they don’t work. Nearly everything I have tried has worked and it’s been a revelation, but I struggling in some situations with WHERE data command.
When I create a dataview query with a WHERE filter of Company = “companyA”, if:
  • the page has one instance of the key in the frontmatter - the page is captured in the report
  • the page has one or more instances of the key inline with same value for the key - the page is not captured
  • the page has multiple instances of the key with different values for the key - the page is not captured
  • the page has one instance of the key in the frontmatter AND one or more inline - the page is not captured
  • the page has one instance of the key in the frontmatter AND inline in a task - the page is captured
  • the page has multiple identical instances of the key in the frontmatter - the page is captured (I tested this for completeness - it’s not actually useful for me)
For the Who or Guest objects, the page is not captured for a where like
WHERE Who = “Paul”
WHERE Guest.Name = “Paul”
What I was expecting to happen is that WHERE would match any page that has a hit, irrespective of whether there are other misses on the same page.
For example, I was hoping to capture every meeting where I met or discussed a given company - and similarly, meetings where a specific person was present.
It’s quite likely I am doing something wrong: syntax, expectations, the wrong key/tag approach completely etc.
Appreciate any pointers - thanks
Alan
Topic
Summary
  • How to check if an element exists in an array using contains from the files with the case_YAML_Y_AoH structure? ( DQL10, DQL20)
Test
Summary
  • dataview: v0.5.55
Input
Summary
dictionary files
  • Location: “100_Project/02_dataview/Q28_contains/Q28_test_data”
folder: 03
  • filename : dic_19560301
```md
Date: 1956-03-01
Time: 14:00
Company: companyA
Who:
  - Paul
  - John
  - Ringo
  - George
Guest:
Company:: companyB
folder: 08_excluded
  • filename : dic_19560801
```md
Date: 1956-08-01
Time: 14:00
Company: companyC
Who:
  - Paul
  - John
  - Ringo
  - George
Guest:
Company:: companyB
folder: 09_excluded
  • filename : dic_19560901
```md
Date: 1956-09-01
Time: 14:00
Company: companyA
Who:
  - Paul
  - John
  - Ringo
  - George
Guest:
  - {NameTmp: "Paul", Instrument: "Bass", Band: "Beatles"}
  - {NameTmp: "John", Instrument: "Piano", Band: "Beatles"}
Company:: companyB
DQL10_check_if_an_element_exists_in_an_array_using_contains_and_TABLE
Summary
Main DQL
Code Name Data type Group By Purposes Remark
DQL10
_check_if
_an_element_exists
_in_an_array
_using_contains
_and_TABLE
(Meeting notes)
Company:
a list of strings
Who:
a list of strings
Guest:
a list of JavaScript Objects
no 1.To filter by Company
2.To filter by Who
3.To filter by Guest.Name
4.To sort by file.name in ascending order
5.To display the result as a table
Code DQL10_check_if_an_element_exists_in_an_array_using_contains_and_TABLE
Summary_code
title: DQL10_check_if_an_element_exists_in_an_array_using_contains_and_TABLE => 1.To filter by `Company` 2.To filter by `Who` 3.To filter by `Guest.Name` 4.To sort by `file.name` in ascending order 5.To display the result as a table
collapse: close
icon:
color:
```dataview
TABLE WITHOUT ID
      file.link AS "FILE",
      Company AS "Company",
      Who AS "Who",
      Who AS "Guest"
FROM "100_Project/02_dataview/Q28_contains/Q28_test_data"
WHERE Company
WHERE contains(Company, "companyA")
WHERE contains(Who, "Paul")
WHERE contains(Guest.Name, "Paul")
SORT file.name ASC
Screenshots(DQL10):
DQL20_check_if_an_element_exists_in_an_array_using_FLATTEN_and_TABLE
Summary
Main DQL
DQL20
_check_if
_an_element_exists
_in_an_array
_using_FLATTEN
_and_TABLE
(Meeting notes)
Company:
a list of strings
Who:
a list of strings
Guest:
2.To dedfine three field variables :
2.1 To split up a list Company into each individual element OneCompany
2.2 To split up a list Who into each individual element OneWho
2.3 To split up a list Guest into each individual element OneGuest
3.To filter :
3.1 To filter by OneCompany
3.2 To filter by OneWho
3.3 To filter by OneGuest.Name
Notes:
Summary
Q1: What is the data structure of the file dic_19560301?
Summary_Q1
Original Example: Q1 (To be explained)
```md
Date: 1956-03-01
Time: 14:00
Company: companyA
Who:
- Paul
- John
- Ringo
- George
Guest:
Company:: companyB
A1_11:
Another Example: A1_11
```JSON
    "Date": "1956-03-01T00:00:00.000Z",
    "Time": 840,
    "Company": "companyA, companyB",
    "Who": [
        "Paul",
        "John",
        "Ringo",
        "George"
    "Guest": [
            "Name": "Paul",
            "Instrument": "Bass",
            "Band": "Beatles"
            "Name": "John",
            "Instrument": "Piano",
            "Band": "Beatles"
Q2: What is the equivalent code for the following code?
Summary_Q2
Original Example: Q2 (To be explained)
```md
WHERE OneCompany = "companyA"
WHERE OneWho = "Paul"
WHERE OneGuest.Name = "Paul"
A2_21:
Another Example: A2_21
```md
WHERE econtains(OneCompany, "companyA")
WHERE econtains(OneWho, "Paul")
WHERE econtains(OneGuest.Name, "Paul")
Code DQL20_check_if_an_element_exists_in_an_array_using_FLATTEN_and_TABLE
Summary_code
title: DQL20_check_if_an_element_exists_in_an_array_using_FLATTEN_and_TABLE => 1.To filter by `Company` 2.To dedfine three field variables : 2.1 To split up a list `Company` into each individual element `OneCompany` 2.2 To split up a list `Who` into each individual element `OneWho` 2.3 To split up a list `Guest` into each individual element `OneGuest` 3.To filter : 3.1 To filter by `OneCompany`  3.2 To filter by `OneWho`  3.3 To filter by `OneGuest.Name`  4.To sort by `file.name` in ascending order  5.To display the result as a table
collapse: close
icon:
color:
```dataview
TABLE WITHOUT ID
      Who AS "Who",
      Who AS "Guest",
      OneCompany,
      OneWho,
      OneGuest,
      OneGuest.Name
WHERE Company
FLATTEN Company AS OneCompany
FLATTEN Who AS OneWho
FLATTEN Guest AS OneGuest
SORT file.name ASC
Screenshots(DQL20):
Reference
Summary
Q06_Monitoring: case_DVIF_DSS
Q06_Monitoring: 【Explanation: the DVJS03】 > 【Step M23: split up】
NOTE: Using data structures and examples to explain the FLATTEN operator
Q06_Monitoring: DQL10
  • Q06_Monitoring: Part02_DQL10+DVJS10: Solutions
contains() vs. econtains()
contains()
econtains()
@justdoitcc brilliant - thank you! Just using “contains” in the WHERE filter solved all of my issues.
There is so much more in your reply that I am sure I will use as well as I continue to refine things - thank you!
