Help with query
Hi everybody
I have a note with a front matter property called group-by that I would like to use just to change the results of a query.
The dataview query in the same page should retrieve the value in this group-by property, this way:
TASK
GROUP BY this.group-by
Then, changing the value of the property the grouping result of the query should automatically update
I tried as well with:
TASK
GROUP BY substring(this.group-by, 0)
Neither works
Anybody can give me a hand with this? Is it even possible with a simple dataview query?
Thanks in advance
What is the content of the group-by property? Is it the name of another property? If so, try using GROUP BY row[this.group-by]
Good night my friend. Right, I guess that’s an important information. The content is a text, with possible values identical to inline fields that each task might have.
This in order to group the wiery results by that very field content.
Let’s say a task can have for ex. an inline field such as [assignee:: Coleridge], another like [area:: HR]. I would like to query and group by assignees or areas, switching views just by changing the property in the page from group-by: assignee to group-by: area
Hope its clear. Thanks in any case
I actually tried what you suggested and it looks like working perfectly. I would have never got to it. I ll do a couple tests more and confirm. Thanks so much for now!
Thanks so much. It really works well. Just a detail if you could help me. Otherwise fine, its already good enough ad it is.
If I enter something as “assignee” or “area” or whatever in group-by its fine, but it doesn’t group if I enter some kind of file property like, for ex, file.name (which is the only one I would use, actually). Will there be a way around it?
I don’t think you’re able to use file.name using this method. I’ve not tested that variant.
Thank you very much anyways
