Hi all,
I can’t find an answer to such a simple query, I am new to MD so might have to do with that, not sure.
Basically, how do I make the text expand in my screen real estate? it seems to use just a tiny portion of the note:
Thanks
P
In Settings you can disable Readable Line Length. Or, you can use Ctrl +/- to zoom interface and note.
Sometimes you may want to split pane vertically and have the panes linked with one in preview mode and the other in edit.
Good luck.
Thanks.
@pakyrs did @I-d-as 's solution seems to be what you need. I’ll mark it as resolved, but feel free to let me know if that wasn’t what you were looking for!
