Help with matchinng string using "this.file.key"
File 1
📆(RecurTaskScheduleDate:: Friday)
File 2
(DateWeekday:: Friday)
TASK
WHERE contains(RecurTaskScheduleDate, "this.file.DateWeekday")
TASK
WHERE RecurTaskScheduleDate = this.file.DateWeekday
TASK
WHERE RecurTaskScheduleDate = "this.file.DateWeekday"
Basically fully match the contents of an inline field with another one referencing the another inline field from the file itself.
Hi.
Maybe WHERE RecurTaskScheduleDate = this.DateWeekday…
Only the implicit fields use the prefix file (because fields related with page «metadata»); created fields don’t need this prefix.
However, you’re working with tasks and inline fields in task text are “nested” fields under the task-level (a sub-level of the “file”). But tasks queries working in both levels (file and tasks), that’s why you don’t need to distinguish RecurTaskScheduleDate with file.tasks.RecurTaskScheduleDate.
