Help with LiveSync
I am trying to self host syncing with LiveSync (their github)
I have managed to get it running on my server using a docker container although I don’t know how I can connect to it. As it is private there is no need for a URI so I don’t know what to put in the URI section. I also don’t know what to put into the database name section. Thanks!
Hi. I am using the LiveSync plugin, but I have not set up a private CouchDB, so I apologize if I am missing something.
If it doesn’t work, you might want to post a question in vrtmrz/obsidian-livesync - Discussions - GitHub.
  1. URI
    obsidian-livesync/docs/quick_setup.md at main · vrtmrz/obsidian-livesync
    https://github.com/vrtmrz/obsidian-livesync/blob/main/docs/quick_setup.md
    e.g. http://localhost:5984 ?
  2. database name
    obsidian-livesync/docs/settings.md at main · vrtmrz/obsidian-livesync
    https://github.com/vrtmrz/obsidian-livesync/blob/main/docs/settings.md#remote-database-configurations
Database Name
The Database name to synchronize.
:warning:If not exist, created automatically.
We wish you luck.
I have managed to get started on the wizard. How would I find the database name?
I now get that it is created when it starts but where can I find what it is called?
I will contact them on github later today.
