Help with dataview group and sum
I have data in the following format in daily notes:
Day 1
Item:: Coffee - 3.00
Day 2
Item:: Coffee - 2.80
Item:: Juice - 3.30
Day 3
Item:: Donuts - 1.8
Item:: Burger - 4.60
Day 4
Item:: Coffee - 3.20
Item:: Donuts - 1.80
Day 5
With the following query I’m getting a table that lists all items.
TABLE WITHOUT ID split(Item, " - ")[0] AS Item, number(Item) as "Amount"
WHERE Item
FLATTEN Item
SORT file.ctime
I can’t figure out how to get a list of Grouped Sums by Item (Coffee,Donuts etc), I would like also to format all output number with two decimals.
Any ideas ?
I built up the same test set, and executed this query on it:
```dataview
TABLE item, i, j
WHERE item
SORT file.ctime
FLATTEN item as i
FLATTEN list(split(i, "\s*-\s*")) as j
Which gave me this output:
Here we can see that the initial list of items is shown in second column and after that has been flattened into i, we see a single item in the third column (with the corresponding list repeated in the second column). This is further split into a list j which holds the distinct entries (in the fourth column). I’ve used a slightly more accepting regex to accommodate for any amount of spaces around the dash to do the split.
Finding our bits and pieces
Now we’re ready to tackle the main issue, with the knowledge that j[0] is our item (or thingy, as I’ve called it in the query below), and the cost from number(j[1]) translated into a number to make the calculations easier.
Your first question then simply becomes a GROUP BY thingy, which will move all other fields into the rows object, so now we can do sum(rows.cost) as sum to get the sum of costs for that particular item.
You also wanted to present the output with two decimals, which is actually harder than it looks within dataview. You can round the answer to two decimals using round(sum, 2) as sum2, but when it’s presented and the last digit is zero it’s dropped.
The most reliable way to get two decimals that I’ve found is to multiply by 100, convert to a string, and “manually” insert the decimal point at the correct position. Aka regexreplace(string(round(sum*100)), "(..)$", ".$1") as sum3.
Here is a query showing all those sums, and doing these operations:
```dataview
TABLE WITHOUT ID thingy, sum, sum2, sum3
WHERE item
SORT file.ctime
FLATTEN item as i
FLATTEN j[0] as thingy
FLATTEN number(j[1]) as cost
GROUP BY thingy
FLATTEN sum(rows.cost) as sum
FLATTEN round(sum, 2) as sum2
FLATTEN regexreplace(string(round(sum*100)), "(..)$", ".$1") as sum3
Which displays as:
This is the verbose version of this query, and you most likely don’t care about all those intermediate sums and so on, so the most condensed version, but still keeping the naming of the cost:
```dataview
TABLE WITHOUT ID key as Item, sum as "Cost"
WHERE item
SORT file.ctime
FLATTEN item as i
GROUP BY j[0]
FLATTEN regexreplace(string(round(sum(rows.cost)*100)), "(..)$", ".$1") as sum
Which then displays as:
Thanks a lot @holroy this is what I was looking for.
Is it possible to have the total Cost.
You’ve got two options (at least), and that is either to do the sum in a separate query below the other, or you could trigger the query from within a dataviewjs script which can add the sum in a new last row. A long (and somewhat hairy) description on the latter approach can be found in the post below:
But we can try to adapt it here for both cases.
Using a separate table
Instead of grouping on the item themselves, we can do a general grouping, using GROUP BY true, and end up with something like:
```dataview
TABLE WITHOUT ID sum as "Total cost"
WHERE file.folder = this.file.folder
WHERE item
SORT file.ctime
FLATTEN item as i
GROUP BY true
Essentially I’ve only changed the grouping, and removed the key from the presentation. And we end up with:
Extending the table using dataviewjs
Even though it kind of looks overwhelming, bear in mind that for later re-use all you need to do is to test and verify your query to show the correct stuff, and then replace it within the call to await dv.query(` … `), and also correct which column you want to sum (with 0 for the first column).
```dataviewjs
const result = await dv.query(`
  WHERE item
  SORT file.ctime
  FLATTEN item as i
  GROUP BY j[0]
if ( result.successful ) {
  const values = result.value.values
  const sum = values.map(v => v[1]) // <-- Column to sum
    .reduce((acc, tmp) => acc + parseFloat(tmp), 0.0)
  values.push([
    `_<span style="float: right">Total</span>_`,
    (Math.round(sum*100)/100).toFixed(2),
  dv.table(result.value.headers, values)
} else
  dv.paragraph("~~~~\n" + result.error + "\n~~~~")
Also if you want to adapt this to some other query with a different column count, be sure to add something to the corresponding entries in the values.push() line. Simply add "", on a line of its own to insert an empty column.
Using the query above we get this output:
Thanks a lot again, I add the dv.paragraph("Total amount: " + (Math.round(sum*100)/100).toFixed(2)) after dv.table… in order to get a simple line of total.
I found something weird, when I use negatives values (occasionally) the group disappears from the output.
Is there a way to keep the data in order when its put into the table? I have a similar list of projects and I’m calculating the total sum of hours spent. Same as @giannis need just replace cost with hours and donuts with project name. My data looks like this:
2024-08-15
Item:: A Project - 2
2024-08-22
Item:: Z Project - 2
2024-09-14
Item:: F Project - 8
Its not critical, but would be nice if this information was kept in order and not sorted alphabetical. I used your code from this snippet: Extending the table using dataviewjs
To keep the order to need to rewrite the queries and remove any sorting and grouping. Instead you would most likely also need to redo the sum function to accommodate for stuff not being in order.
So it’s doable, but it would require some rearranging and recalculation.
thanks a lot, it is super helpful!
