Use Annotator
Unfortunately, this report is too short to be useful.
I can only guess that you wanna load a PDF in Annotator:
annotation-target: xxx
Replace the x with your PDF URL path. If the path to your PDF is correct, your PDF will open in Annotator.
Consider to read again the readme on Sundqvists GitHub page.
The way I added pdf files:
annotation-target![[Name.pdf]]First, I need to apologize for my poor English.
Secondly, I found two problems that looks not right:
Annotator plugin has a better alternative, if you don’t mind me offering it: PDF++
It is actively maintained, even.
No need to apologize, people of all nationalities use Obsidian. We all try our best to convey meaningful messages. Not always an easy task, no matter what language we speak. Also, not everyone knows English well, but barriers shouldn’t stop you from asking !
I’m glad you could resolve, Annotator is a great plugin but a bit old and to add a path isn’t user friendly.
As Yurcee pointed out, take a look at PDF++, this plugin is easier to use and up to date.
