Help Using Regex search within Obsidian
Help! Trying to use Regex in Obsidian. I have learned a couple of expressions but unable to implement. Is there a specific character or command or plugin that I might need before using Regex?
I have tried using the / and \ characters, but could not get any result in the search box.
Thank you
You need to put the expression between / .
What expression have you tried ?
Thanks Anwen,
Here’s what I have tried for the following purpose. My apology I should have stated original.
I have several thousand files prefixed by date in the following format yyyymmdd.
I am trying to find all files for the year 2017 and which contains the word “doctorate”.
Here are some of the expressions I have attempted.
/2\0\1\7\d\d\d\d/ doctorate
/\2017\d\d\d\d/
regex /2017\d\d\d\d/
Thanks again!
https://help.obsidian.md/Plugins/Search#Use+regular+expressions
Which ends with a link to a more detailed guide to the flavor of regular expressions supports.
Also to search in note names you can use file:2017.
Thanks, I will try your suggestion and provide feedback.
