What I’m trying to do and what I’ve tried
I have a base for all my notes. I’m using Tiago Forte’s progressive summarization, with some modifications. This is my base: it looks for any note that is in my summarization workflow. I’ve removed some of the views for simplicity.
filters:
not:
- file.path.startsWith("01 - Projects")
- file.path.startsWith("Templates")
- file.path.startsWith("Archive")
- type == "Daily Note"
- type == "Weekly Note"
- type == "Monthly Note"
- type == "Quarterly Note"
- type == "Yearly Note"
- file.path.startsWith("02 - Areas/+ 02 Weekly Notes/Weekly Archives")
- type: table
groupBy:
property: summary_progress
direction: ASC
- type: table
filters:
and:
- summary_progress == "L1_Notes"
- type: table
filters:
and:
- summary_progress.isEmpty()
I want to create a dashboard to work through my notes. I want to limit the number of visible notes to 10-15 per view, but I want them to be randomized whenever the table updates.
Whenever I add the random function, it does nothing.
- type: table
filters:
and:
- random()
limit: 10
Or, if I add the random() function with a ratio it says I have less notes than I did without the function in. And the number changes based on the decimal I use.
- type: table
filters:
and:
- random() >= .9
limit: 10
What am I doing wrong?
