Help-Tracker plugin
looked youtube videos, checked help here.
I am trying to write a simple tracker query
searchType: dvField
searchTarget: meditate
folder:DailyNotes
month
every time I am getting " Error Parsing YAML" . what am i doing wrong
If this is your YAML I see (1) folder:DailyNotes needs a space between the colon and the value; and (2) the month value needs to have a key like month: February. You can use something like https://www.yamllint.com/ in order to make sure you are writing valid YAML.
thank you!. silly mistake and thanks for pointing it out. issue was month: 1
