Help to custom Time ruler plugin / Dataview filter function
I’m trying to set up the Time ruler plugin to show only tasks that are in files with the #todo tag.
In the setting there’s 3 options
But I can’t find out which dataview syntax I have to use, nor the difference between this 3 options.
I read carefully the documentation setting and the dataview syntax guide,
and watched a Dataview beginner’s tutorial for obsidian. I’ve learned a lot, but I still don’t have any clue what do I have to write and where :sob:
There only one topic open now about Time ruler setting, that’s doesn’t answer the question so far…
Any help is very welcome !!
In the Custom Filter setting, try "#todo" with the quotes
From This link in the data view docs.
The custom filter field in the time ruler settings is passed to dv.pages
Oh sorry, I just tried it and you don’t need to put in the quotes.
Thanks, I will try it…
