Hi, My mac has been formatted and Obsidian has been deleted.
I download it again but when charging my vault, the error message appears " failed to load plugin table editor"
I’m now using McOS Monterey 12.3
How can I fix this issue, do you have any documentation please ?
I try to uninstal several times but doesnt’ work.
Thanks
I think “table-editor” is another name for the community plugin “Advanced Tables”. Have you gone to “Settings” → “Community Plugins” and re-installed any that you were using before? While there, might as well check for updates!
