Help on embedding a callout from another page
Hello.
I ve read how to embed a page ![…] and i also use the same with #id
But now i ve another question.
I would like to start a “decision journal”, which basically show what i did a year before.
I just need to embed a part, which to my dismay is not a Heading.
it s a callout → [!ABSTRACT] Summary of the day
I tried to add a # after Summary, but the embedding#id is not working
is there a workaround?
Thanks
You should be able to use a block id to embed a callout. It can be auto-generated (like this one) or a name of your choosing.
Type ![[ → start typing the name of the note and you’ll get note suggestions → arrow key to the note but don’t type enter/return
→ type ^ → choose the block → type enter/return.
The callout in the main note:
> [!example] journal
> - one
> - two
> - three
^23cf7a
The embed:
![[pineapple#^23cf7a]]
Thanks! this helped a lot…
Hello Ariehen,
I ask something a bit outside the scope of this tread, but i think it useful to have them together
my daily template is
Notes of {{DATE:dddd, DD-MM-YY}}
[!ABSTRACT]+ Summary of the day
Contents
  • 1 win from the day
  • 1 point of tension, anxiety, or stress
  • 1 point of gratitude
and so on.
Under the summary of the day of the current year
I would like to have embeded the “summary of the day of Year -1, -2…”
now i know i can call it with the [[ + ^
but is there a way to add it into a template?
On this post i’ve learn the smart trick of “one year ago”
path:Planner file:"{{date:-MM-DD}}" -file:"{{date:YYYY}}-"
How can i add the specific section with the above trick?
thanks
Manolo
It’s best to open a new topic for a different issue, especially one that has been marked as solved :white_check_mark:. Then others will be more likely to jump in and offer suggestions.
