Hi,
I’m still stuck on my templater script, to create automated Highlight notes.
I explained my workflow here and @ninjineer helped a lot with some very good advices.
As it was kind of wild for me that time, I did not have the time, to follow up this issue. But now, I want to continue solving that problem.
The last unsolved problem in that script is, that in the end it doesn’t create a new file. There must be a problem with the “tp.file.create_new”-function…
Templater script
//If you're working with note `report-today` in folder `reports` which is in
//the `projects` folder which is the root level of the vault:
const template = tp.file.find_tfile('highlight-note template');
const path = tp.file.path(true);
//Returns the note file's path relative to the vault root. It includes the
//file's `.md` extension
console.log(`path = '${path}'`);
//path = 'projects/reports/report-today.md'
const slash = path.lastIndexOf('/');
//This command looks for the first `/` character starting from the end of the
//string and returns its position in the string. To the right of this location
//is the note's file name. To the left is relative path within the vault where
//where that note is kept. `lastIndexOf` will return -1 if the search string
//is not found in the source string, which here means the note file is located
//in the vault's root folder.
console.log(`slash = ${slash}`);
//slash = 16
let folder = '';
//Empty string here represents the root folder of the vault;
if (slash > 0) folder = path.slice(0,slash+1);
//If a `/` was found, chop off the file name portion
// ... geht auch einfacher, nämlich wie in der templater doc zu lesen:
console.log(`folder = '${folder}'`);
//folder = 'projects/reports/'
let i = 1;
let new_filename = folder + tp.file.title + "_H"
while(await tp.file.exists(new_filename + i + ".md")) {
i++;
if (i === 100) {
console.log("too much iterations");
break
let filename = `${tp.file.title}_H${i}`;
await tp.file.create_new(template, filename, false, folder);
tR += `![[${filename}]]`;
And here the console log:
plugin:templater-obsidian:61 Templater Error: Couldn’t create markdown file. e.getParentPrefix is not a function
log_error | @ | plugin:templater-obsidian:61 | |
errorWrapper | @ | plugin:templater-obsidian:83 | |
await in errorWrapper (async) | |||
create_new_note_from_template | @ | plugin:templater-obsidian:3588 | |
eval | @ | plugin:templater-obsidian:2411 | |
eval | @ | VM228:100 | |
await in eval (async) | |||
eval | @ | plugin:templater-obsidian:3455 | |
handleError | @ | plugin:templater-obsidian:3242 | |
imports.wbg.__wbg_call_168da88779e35f61 | @ | plugin:templater-obsidian:3454 | |
$func105 | @ | 00032406:0xa737 | |
$func27 | @ | 00032406:0x5c9b | |
$renderer_render_content | @ | 00032406:0x8cd8 | |
render_content | @ | plugin:templater-obsidian:3379 | |
parse_commands | @ | plugin:templater-obsidian:3511 | |
parse_template | @ | plugin:templater-obsidian:3553 | |
await in parse_template (async) | |||
read_and_parse_template | @ | plugin:templater-obsidian:3548 | |
await in read_and_parse_template (async) | |||
eval | @ | plugin:templater-obsidian:3639 | |
errorWrapper | @ | plugin:templater-obsidian:80 | |
append_template_to_active_file | @ | plugin:templater-obsidian:3639 | |
onChooseItem | @ | plugin:templater-obsidian:2262 | |
t.onChooseSuggestion | @ | app.js:1 | |
t.selectSuggestion | @ | app.js:1 | |
e.useSelectedItem | @ | app.js:1 | |
(anonymous) | @ | app.js:1 | |
e.handleKey | @ | app.js:1 | |
e.onKeyEvent | @ | app.js:1 |
What does this console log mean? Why wasn’t it possible to create the new file?
Thanks in advance,
kind regards,
Silias
