Help Needed: Displaying LaTeX Equations Generated by GPT-4o with TextGenerator Extension
Hi everyone,
I’m using the TextGenerator extension in Obsidian and have it connected to GPT-4o. When I generate answers that include LaTeX equations, the equations are often enclosed in \( and \) instead of the usual $ used by Obsidian.
Is there an effective way to display these generated LaTeX equations properly within Obsidian? Any tips or recommended settings would be greatly appreciated.
Thank you for your help!
What have you tried so far?
You could ask GPT-4o for the answer.
Thank you sir.
I have tried to Using temperater extension.
I was wondering if there is a way to solve this problem programmatically. I have absolutely no knowledge of programming.
I never thought I would be able to solve it with prompts, thank you so much.
