Help Needed: "Could not make design documents" Error with CouchDB 3.3.3 on Unraid
Hello everyone,
I’ve been encountering an issue after setting up “CouchDB” version 3.3.3 on my Unraid server. I aim to sync my Obsidian notes using the "self-host live Sync "plugin, and while I believe I’ve configured everything correctly, I’m running into a “Could not make design documents” error during the sync process.
I’ve double-checked my permissions, gone through the usual troubleshooting steps like restarting the CouchDB service, and scrutinizing the log files, but to no avail. This is my first time deploying CouchDB on Unraid, so I’m wondering if I might have missed a crucial step in the configuration, especially since I’ve altered the default file storage paths to save data on my array.
Would any seasoned Unraid or CouchDB users be able to offer some guidance? Or if you’ve faced and resolved a similar issue before, could you share your solution?
I’d greatly appreciate any help you can provide!
Additional details:
Looking forward to your responses!
Best regards,
