Hello,
My Idea is:
When I open Tab 1: That tab includes 3 columns like the image, similar to tab2,3…
When code alone each plugin show exactly things:
For tab-plugin:
the code:
````tabs
tab: Tab 1
tab: Tab 2
tab: Tab 3
The result:
For multi-columns-plugin:
the code:
--- start-multi-column:
```column-settings
number of columns: 3
shadow: off
# Column 1
--- end-column ---
# Column 2
--- end-column ---
# Column 3
--- end-multi-column
the result:
But when I put all together, it do not show what I want. How to fix it?
Thank you very much!
````tabs
tab: Tab 1
```column-settings
shadow: off
# Column 1
--- end-column ---
# Column 2
--- end-column ---
# Column 3
tab: Tab 2
tab: Tab 3
The result:
