Help identifying side bar item/plug-in
Hi guys,
Can someone kindly identify this plug-in/item in the sidebar of @nickmilo’s LYT kit?
I love an outline and would like to implement this in my vault.
Thanks
That is the Outline core plugin,
once enabled it will show up on the right side by default.
As with pretty much every pane you can move it to wherever you like.
Thanks for the response. I was looking at the Outliner plug-in in Community plug-ins, and that’s why I couldn’t work it out.
Thanks for replying.
