e using. You can find their GitHub address in the community theme list. -->
Click the help icon in LH toolbar and nothing happens
I’m a new user so have not seen help work. I figured there should be pop-up or a new panel opened
Nothing
  • Operating system: Win 10 Pro
  • Obsidian version:
    V0.8.12
I checked the ‘Obsidian Help’ folder and it contains a ‘How To’ folder that contains help-looking files
files 2
Hm. Did you do anything to the Obsidian directory before trying this the first time?
I was using Help just yesterday with no issues, but I’m on macOS. So maybe it is OS-specific.
You may want to try reinstalling the app as a quick fix.
I have done a reinstall and now have it working. See here for the story:
