Windows must use the color scheme set in the settings.
Windows do not use the color scheme set in the settings.
Obsidian version: v1.5.12
Installer version: v1.5.8
Operating system: Darwin Kernel Version 23.2.0: Wed Nov 15 21:53:34 PST 2023; root:xnu-10002.61.3~2/RELEASE_ARM64_T8103 23.2.0
Live preview: off
Base theme: light
So, it was always this way, at first mainly for branding, cause the website is also using dark mode.
But, there are also a few other problems:
The color scheme is set per vault, we don’t offer a global setting for it.
If we use “Adapt to system” we run into issues with users that prefer dark mode.
We would swap the color scheme for most users who haven’t changed the system setting, especially on Windows, since the system theme is not that noticeable there, especially on older systems.
I wouldn’t confuse branding with bad design. For branding there is the about window. There you can experiment with colors, shapes and more. The main program windows should look standard.
