Hi Everyone,
I’m trying to figure out how to apply a box-shadow to my code blocks.
Can someone let me know how to accomplish this?
This does it:
/* reading view */
.el-pre:has(> pre > code) {
box-shadow: 2px 2px 10px 0 rgb(var(--mono-rgb-100), 0.15);
/* editing views */
.HyperMD-codeblock {
box-shadow: 2px 10px 10px 0 rgb(var(--mono-rgb-100), 0.15);
I cheated a little for the editing views. A code block there isn’t really a block but individual lines. So I chose values that would “hide” parts of the shadows. You’ll see what I mean if you adjust the shadows by more than a couple of pixels.
If you’re okay with the widths above,
. But if you want to change them and avoid having shadows between each line, then here are the individual selectors to work with:
.HyperMD-codeblock-begin {}
.HyperMD-codeblock-end {}
.HyperMD-codeblock:not(.HyperMD-codeblock-begin, .HyperMD-codeblock-end) {}
