And I would like to know if it is possible to do that.
Thanks in advance!
I’ve tried to do it without spaces, even with the icon but with no spaces, and it works perfectly. But I would like to know if it’s possible to include that space.
Thank you! I’m not sure if I’ve write right the angular brackets but the %20 works really fine. Just to know, would you mind to type me how should look this code with the angular brackets?
It seems like you’ve omitted parts of the code, but I’ve seen some use this format for links: [display text](<url potentially with spaces>). I’m not quite sure handles this variant, but I think it should work that way too. That is with text (not non-charaters) replaced with someone meaningful.
