Heading collapse indicator is displaced in Reading Mode and dots don't appear when collapsed
Heading collapse indicator is displaced in Reading Mode and dots don’t appear when collapsed
  1. Create a heading
  2. Go to Reading Mode
  3. Hover the created heading
Y
The heading collapse indicator should be beside the hovered heading, and when clicked the heading should collapse and 3 dots (“…”) should appear after the heading.
The heading collapse indicator is on the top of the note, and when clicked, the 3 dots (“…”) do not appear.
example
Obsidian version: v1.7.6
Installer version: v1.4.13
Operating system: Windows 10 Pro 10.0.26100
I believe that the displacement problem is caused by the following CSS rule:
.markdown-preview-view .collapse-indicator {
    top: 0;
This rule is defined here: “app.css:5564”.
The following CSS snippet solves the displacement issue:
    top: inherit;
thanks
Same issue
Please fix it
All the Heading (###) unfold arrows stacked on top right with the latest update
Addition. If there are several headings and some of them are opened or closed in editor mode, then in viewing mode they will remain in the same state and it will be impossible to change their state, since the corresponding markers are not displayed. Only for the lowest heading there is a marker that is displayed at the top of the note, as in the author’s video
Same issue the “>” won`t appear or displaced in reading mode
it will be fixed v1.7.7
Is there a release date? Thanks
No ETAs, sorry.
Yes seems that there’s CSS error in app.css where the arrow is positioned to top: 0 so all arrows stack to the very top.
    position: absolute;
    /* top: 0; */
    cursor: var(--cursor);
Aqui também está acontecendo o mesmo problema, O indicador de recolhimento do título não está funcionando no Modo de Leitura
