Note: I originally thought this was only an issue of the outline, but even links created via the suggestion popup after typing
for example do the very same. The problem is broader and there may be existing topics about this.
## [Google](https://www.google.com/)
Drag the heading “Google” from the outline into the source/live preview mode.
[[#[Google](https //www.google.com/)|Google]]
I’d expect the link to look clean, i.e. have display text equal to the heading excluding its link.
I’d also expect if a header has the command Rename this heading used on it, in addition to renaming links to this header in the vault, also rename the display texts (unless they’re not exactly identical to their heading, e.g. only also rename display text “Google” if is it’s “Google”, not “Google is a search engine”).
[[#[Google](https //www.google.com/)]]
Other examples
A wikilinked header with display text
## [[Some note|The best note]]
When linking to the header results in:
[[#Some note The best note]]
When it should probably be:
[[#Some note|The best note]]
Obsidian version: v1.5.3
Installer version: v1.5.3
Operating system: Windows 10 Pro 10.0.22631
