Having issues with community plugins: random toggles & settings reset
I observe at least five distinct issues relating to community plugins that I suspect could be attributed to a single cause.
The following plugins “forget” that I enabled or disabled them (i.e. toggled them ON or OFF):
  1. Creases gets enabled on its own
  2. CustomJS gets enabled on its own
  3. Text Transporter get disabled on its own
  4. Nuke Orphans gets disabled on its own
This happens seemingly at random: sometimes when I relaunch Obsidian, other times not :man_shrugging:
Also, when I turn the restricted mode ON and then OFF, Novel word count’s settings restore to default. I can’t reproduce this in the sandbox vault though (and neither can the plugin’s dev).
I use iCloud for syncing. What could be the issue?
Here’s an example:
community-plugins.json - on Obsidian quit (macOS)
I have wrapped the change in **.
  "cmdr",
  "create-note-in-folder",
  "put-first-line-in-title",
  "obsidian-shortcuts-for-starred-files",
  "obsidian-image-toolkit",
  "lazy-plugins",
  "merge-notes",
  "pane-relief",
  "quick-explorer",
  "trigger-manual-save",
  "obsidian-linter",
  "obsidian-style-settings",
  "darlal-switcher-plus",
  "obsidian-minimal-settings",
  "quick-tagger",
  "templater-obsidian",
  "obsidian-copy-block-link",
  "mononote",
  "tag-wrangler",
  "adapt-to-current-view",
  "auto-card-link",
  "obsidian-auto-link-title",
  "obsidian-folder-focus-mode",
  "obsidian-hider",
  "novel-word-count",
  "obsidian-outliner",
  "obsidian42-strange-new-worlds",
  "text-extractor",
  "obsidian-zoom",
  "omnisearch",
  "obsidian-trash-explorer",
  "customjs",
  **"obsidian42-text-transporter"**
community-plugins.json - on subsequent Obsidian launch right after (macOS)
  "cmdr",
  "lazy-plugins",
  "merge-notes",
  "pane-relief",
  "quick-explorer",
  "obsidian-linter",
  "quick-tagger",
  "mononote",
  "tag-wrangler",
  "auto-card-link",
  "obsidian-hider",
  "novel-word-count",
  "text-extractor",
  "obsidian-zoom",
  "omnisearch",
  "customjs",
  **"creases"**
My debug info:
macOS
	Obsidian version: v1.7.7
	Installer version: v1.7.7
	Operating system: Darwin Kernel Version 20.6.0: Thu Jul  6 22:12:47 PDT 2023; root:xnu-7195.141.49.702.12~1/RELEASE_X86_64 20.6.0
	Community theme: Minimal v7.7.18
	Snippets enabled: 16
	Plugins installed: 54
	Plugins enabled: 32
		1: Commander v0.5.2
		2: Create Note in Folder v1.12.4
		3: First Line is Title v1.0.0
		4: Hotkeys for Bookmarks v1.1.1
		5: Image Toolkit v1.4.2
		6: Lazy Plugin Loader v1.0.18
		7: Merge Notes v0.0.9
		8: Pane Relief v0.5.6
		9: Quick Explorer v0.2.12
		10: Trigger Manual Save v1.0.0
		11: Linter v1.27.1
		12: Style Settings v1.0.9
		13: Quick Switcher++ v4.6.2
		14: Minimal Theme Settings v8.1.1
		15: Quick Tagger v2.2.3
		16: Templater v2.9.1
		17: Copy Block Link v1.0.4
		18: Mononote v1.2.2
		19: Tag Wrangler v0.6.1
		20: Adapt to Current View v1.0.0
		21: Auto Card Link v1.2.3
		22: Auto Link Title v1.5.4
		23: Folder Focus Mode v0.9.13
		24: Hider v1.5.1
		25: Novel word count v4.0.0
		26: Outliner v4.8.1
		27: Strange New Worlds v2.1.5
		28: Text Extractor v0.5.2
		29: Zoom v1.1.2
		30: Omnisearch v1.25.1
		31: Trash Explorer v1.2.3
		32: CustomJS v1.0.21
iOS
	Operating system: ios 18.1.1 (Apple iPhone14,5)
	Obsidian version: 1.7.7 (172)
	API version: v1.7.7
	Plugins enabled: 27
		1: Commander v0.5.2
		5: Lazy Plugin Loader v1.0.18
		6: Trigger Manual Save v1.0.0
		7: Linter v1.27.1
		8: Style Settings v1.0.9
		9: Quick Switcher++ v4.6.2
		10: Minimal Theme Settings v8.1.1
		11: Quick Tagger v2.2.3
		12: Templater v2.9.1
		13: CustomJS v1.0.21
		14: Adapt to Current View v1.0.0
		15: Auto Card Link v1.2.3
		16: Auto Link Title v1.5.4
		18: Folder Focus Mode v0.9.13
		19: Mononote v1.2.2
		20: Novel word count v4.0.0
		21: Omnisearch v1.25.1
		22: Outliner v4.8.1
		23: Strange New Worlds v2.1.5
		24: Tag Wrangler v0.6.1
		25: Text Extractor v0.5.2
		26: Trash Explorer v1.2.3
		27: Zoom v1.1.2
  1. Reinstalled each plugin.
  2. Deleted community-plugins.json in the .obsidian folder.
  3. Deleted and reinstalled Obsidian.
It looks like “Lazy plugin loader” was the culprit–its settings kept overwriting the ON/OFF states. I needed to also set them in the plugin’s settings.
My experience with Lazy Plugins:
If you install and enable a new plugin, you need to restart Obsidian for Lazy Plugin to register it in its data.json.
Then you can change from instant to short or long, or from short or long to instant, and the setting will stick.
  • No experience with iCloud, here. I use git.
My only beef with Lazy Plugins is when bringing over large sync updates, the plugins overseen by Lazy put a cramp in Obsidian’s indexing the changes of the updates. So often I rename the community-plugins.json for the duration of the Obsidian index, quit Obsidian, remove the empty community-plugins.json and rename the formerly renamed json to have Lazy load my plugins.
On my new faster laptop Lazy isn’t really needed anymore, but I’ll keep it, because I want to oversee which slots prospective or formerly deactivated plugins (e.g. those doing indexing or needing to be instantly loaded) would go into.
