Its been Years since the discussion on this extremely valuable quest!on started. ![]()
Have we since reached some kind of consensus Solution on how to implement those with obsidian for workflow/graph/ai compatibility and long term scaling ? (so we can pin this for more awareness)
Or have we only just scratched the surface of an Iceberg of complications ?
If you want more details, here’s the vision : ![]()
It’s the ability of Attributing & Adjusting complex Metadata to each Unique links, making Relationships Explicit, Meaningful.
For example some powerful Essential Distinctions are :
Categories
- Asymmetric
- Contextuality (ContentOf//ContextOf) (or PartOf//WholeOf for Holistic thinking)
- Sequentiality (PreludeTo//PostludeTo) (or Before//After for simpler Naviguation)
- Causality (CauseOf//EffectOf for Systems thinking)
- Symmetric
- Synergies
- Conflicts
- Asymmetric
Properties
- Influence (the Degree of Gravity/Intensity of the connection) (represented by the Lenght of the edge)
- Excellence (the Degree of Quality/Reliability of the connection) (represented by the Opacity of the edge)
