Hard to close or swap tabs when fullscreen on Monitor (MacOS)
  1. Connect Mac with a monitor
  2. Open Obsidian Full Screen on the monitor
  3. Try to open up couple tabs
  4. Try to swap tabs by clicking on the tabs, or try to close the tabs by clicking on the “X”
Yes, I tried in SandBox
Be able to click on buttons easily
Observed that it’s hard to close or swap tabs, also hard to press the buttons on the top of the screen, a tag will show up and blocks the click. Seems like UI think that I am dragging while I am actually clicking?
Obsidian version: v1.10.3
Installer version: v1.8.7
Operating system: Darwin Kernel Version 25.0.0: Mon Aug 25 21:27:47 PDT 2025; root:xnu_development-12377.1.9~2/DEVELOPMENT_ARM64_T6041 25.0.0
Plugins installed: 4
Plugins enabled: 3
1: Calendar v1.5.10
2: Paste image rename v1.6.1
3: Node Auto Resize v1.1.0
  1. Does not happen without full screen
  2. Does not happen when I am not using a monitor a
  3. Not sure if it’s a MacOS Bug
Screen Recording 2025-11-17 at 16.40.59
s extension
Additional Information: MacOS Version: Tahoe 26.0.01
Download and install the latest Obsidian and report back. Hopefully that helps.
macOS Tahoe doesn’t play nice with older installers (Electron versions).
I still have this issue on version 1.10.6.
Im also on macOS Tahoe and the issue happens when i am using a monitor
Did you download and reinstall obsidian from the website?
Yep, and the issue is still persisting
