Open Obsidian and open a note. The interface will freeze for 4-5 seconds. Then open another. It will freeze again. Then switch to the previous one. It will freeze again.
I uninstalled and reinstalled Obsidian and the problem remains
I expected it to not hang as it used to do.
The interface freezes every time I switch to another note.
Obsidian version: v1.5.3
Installer version: v1.5.3
Operating system: Darwin Kernel Version 23.3.0: Wed Dec 20 21:28:58 PST 2023; root:xnu-10002.81.5~7/RELEASE_X86_64 23.3.0
Catalyst license: insider
Base theme: light
Community theme: AnuPpuccin v1.4.5
Snippets enabled: 4
Plugins installed: 42
Plugins enabled: 32
1: Advanced URI v1.40.0
2: Auto Note Mover v1.2.0
3: Base Tag Renderer v1.2.1
4: Buttons v0.5.1
5: Calendar v1.5.10
6: Dataview v0.5.64
7: Emoji Shortcodes v2.2.0
8: Linter v1.22.0
9: Map View v4.0.0
10: Minimal Theme Settings v7.3.1
11: Natural Language Dates v0.6.2
12: Outliner v4.8.0
13: Periodic Notes v0.0.17
14: PlantUML v1.7.0
15: Plugin Update Tracker v1.5.2
16: QuickAdd v1.6.1
17: Show Whitespace v0.3.1
18: Templater v2.2.1
19: DB Folder v3.5.1
20: Fast Image Cleaner v0.8.2
21: Filename Heading Sync v1.9.0
22: Book Search v0.5.11
23: MetaEdit v1.8.2
24: Hotkeys for specific files v1.4.1
25: Projects v1.17.1
26: Simple Embeds v1.15.0
27: Tasks v6.0.0
28: Excalidraw v2.0.20
29: Keyword Highlighter v1.2.0
30: Omnisearch v1.21.1
31: Recent Files v1.3.10
32: Multi-Column Markdown v0.9.1
Here is a screen recording of me interacting with the sandbox vault. I’m trying to scroll the whole time but as you can see it stalls for several seconds every time I switch to another file. The spinning wheel cursor shows for most of the time while it’s stuck but for some reason the screen recording doesn’t show it. I hope this helps.
No. Just one user. All normal in my file system: my MacBook Pro internal SSD. I really don’t know what to do but this is making Obsidian unusable since I constantly switch between multiple notes
