- Search on the forum and on Discord about this (haven’t found anything, but maybe didn’t search well enough)
I use a CSS snippet I got from the Organising the Bible in Obsidian thread that transforms H6s into Bible verses:
I use the Minimal theme and the snippet has been working great up until 4.2.0 when the snippet no longer worked as intended, i.e., the verses are no longer visible (the screenshot above shows Minimal 4.1.9, and the one below uses the latest Minimal 5.0.0):
I tried the snippet with a bunch of themes including the default, and the verses are visible even after updating them, so this seems to be unique to Minimal both on desktop and mobile.
This is the snippet I use:
.markdown-preview-view h6
position: relative !important;
text-align: right !important;
left: -101% !important;
top: 27px !important;
line-height: 0px !important;
margin-top: -20px !important;
margin-right: 3px !important;
font-family: var(--font-family-preview) !important;
font-weight: 500 !important !important;
font-size: 12px !important;
color: var(--text-muted) !important;
I have very very little knowledge of CSS, and that is why I’m asking for help on getting this snippet to work with later versions of Minimal. However, from playing a bit with the snippet, I found that when the H6 is vertically positioned far enough from its original position, it starts to disappear. In this case, the limit is very close to the original position that I can’t place the header beside the desired verse without it fading away. In the screenshot below, I positioned it close enough that you can see it only half visible; farther than this and it disappears:
Would really appreciate any help with this! Thank you so much
really appreciate it
