Are there graph view settings that would correct a problem that I am seeing below?
The default graph view for one of my vaults in unclear. I can drag nodes around to make it clearer manually. Obsidian restores the default view whenever I reopen the vault.
Example before manual adjustment:
Same example after manual adjustment:
The specific problem is easier to see if we zoom in on a smaller example from the same graph. Here is one cluster of nodes (with the forces set to make the problem obvious):
This graph has two âwingsâ or ânodesâ that cross over one another unnecessarily. This arrangement is clearer:
It appears as though the nodes are trapped in positions that force the relationship lines to cross. The graph canât âuntwistâ itself once generated this way. Are there settings that would either prevent these twists or, once created, force the nodes out of them? Something that makes Obsidian âstrongly opinionatedâ that relationship lines shall not overlap unless it is unavoidable?
My hope is that solving for this case will untangle the whole graph.
- Fiddling with the graph view force sliders. (Hoping I just havenât stumbled over the right combination.)
- Hiding/showing different node types (vault paths) to see if these allow Obsidian to generate a clean node graph before popping the hidden nodes back into view. (Even worse!)
- Researching the settings in yEd that explicitly reduce the likelihood of edges overlapping to see if any of that translates to Obsidianâs force settings. (Admittedly, I can only do that outside work hours and itâs hard to keep the pieces together mentally over several days.)
- Google searches. (Found a lot of obsidian stone jewelry.)
What Iâm trying to do
Iâm trying to find settings for Obsidianâs graph view so that the edges do not cross unnecessarily, in order to make the graph more legible.
