Graph view not working (v. 1.0)
Problem
Whenever I try to go to the graph view, it just shows me a blank page, both on Windows and Android wich both access the same vault.
This is new since obsidian worked flawless for me since I started using it.
I will add, that my local graph view is still working:
Operating System: Windows 10, Version 22H2 / Android 13
post a screen recording of this not working in the sandbox vault.
Well, it does work in the sandbox vault…
in you vault, enter restricted mode, use default theme, disable snippets. restart obsidian.
Does the graph view work?
Nope, nothing changed
The Graph actually quicky shows up before it disappears:
2022-10-23-14-53-47_Trim
Try turning off all your plugins one by one and trying the graph view, maybe you will pinpoint the cause
Does the graph view work? Post a screen recording.
You may also have a problem with you gpu, settings>about>disable hardware acceleration.
I’m sorry but how do I post a screen recording here?
I got the file just don’t know how to upload it here,
upload it somewhere and attach a link here.
Also do you get errors in console ctrl-shift-i?
Theres the video:
Imgur
Yeah and the console shows me this…
you need to click the console tab and open the graph.
Ok, I don’t know what happened here but it just started working again
Having the same issues. Tried all of the above to no avail.
Perhaps something that would help finding the cause.
Making a new empty directory and open it as a vault.
Copy-Paste all the information of the vault that doesn’t show a graph.
Open Graph view → All is working fine.
If Obsidian was open when entering sleep mode or hibernating the chances that the view doesn’t work are very real.
Caching information? (Just a wild guess)
