I attempt to show the graph view by clicking the icon on the side strip.
I expect to see a full graph of my vault, along with buttons to modify and filter my searches.
I see the links for one random note, and no others (I have hundreds of cards in my vault). There are no buttons or menus for filtering or anything.
- Operating system: MacOS 12.6
Obsidian version: v1.0.0
Installer version: v0.15.6
Operating system: Darwin Kernel Version 21.6.0: Mon Aug 22 20:17:10 PDT 2022; root:xnu-8020.140.49~2/RELEASE_X86_64 21.6.0
Legacy editor: off
Community theme: LYT Mode
Snippets enabled: 2
Plugins installed: 73
Plugins enabled: 59
1: Workbench v1.6.1
2: Table of Contents v0.1.3
3: Completed Task Display v1.0.3
4: Pandoc Plugin v0.4.1
5: Find orphaned files and broken links v1.8.0
6: Tasks v1.15.1
7: Rollover Daily Todos v1.0.5
8: Templater v1.14.3
9: Recent Files v1.3.3
10: Periodic Notes v0.0.17
11: Dataview v0.5.47
12: Advanced Tables v0.17.3
13: Kanban v1.4.6
14: Review v1.6.4
15: Emoji Toolbar v0.3.2
16: Timeline v1.1.0
17: Reminder v1.1.12
18: Zoom v1.1.0
19: Archiver v0.9.0
20: Workspaces Plus v0.3.2
21: Completed Area v0.2.0
22: Longform v1.1.0
23: Stille v1.3.1
24: Ghost Fade Focus v3.0.0
25: Dynamic Table of Contents v0.0.27
26: Map of Content v0.1.18
27: Advanced Cursors v0.5.1
28: Flexible Pomodoro For Obsidian v0.6.0
29: Card View Mode v0.4.10
30: TimeStamper v1.2.0
31: Scales and Chords v1.0.1
32: Hover External Link Plugin v1.0.0
33: Itinerary v1.3.0
34: CardBoard v0.5.0
35: Tomorrow’s Daily Note v1.0.2
36: Commits v0.2.2
37: Calendar v1.5.10
38: Obsidian42 - Jump-to-Date v1.0.13
39: Obsidian Charts v3.6.3
40: Obsidian Big Calendar v0.3.0
41: Full Calendar v0.6.1
42: Upcoming v0.3.0
43: Latex Suite v1.6.0
44: Extract PDF Annotations v1.0.4
45: Better Command Palette v0.14.0
46: Checklist v2.2.10
47: Excalidraw v1.7.25
48: ExcaliBrain v0.1.11
49: Citations v0.4.5
50: Zotero Integration v2.2.30
51: Zotero Bridge v1.2.3
52: Zotero Link v1.0.0
53: Window Collapse v1.0.2
54: Icon Folder v1.3.5
55: Highlightr v1.2.2
56: PDF Highlights v0.0.4
57: Tag Wrangler v0.5.3
58: Note Refactor v1.7.1
59: Obsidian Tabs v1.0.7
I am not sure there’s anything wrong there. Anyway
Base steps:
- Check your Theme for updates: Settings > Appearance > Themes
- Check your plugins for updates: Settings > Community Plugins > Check for updates
- If you’re using custom snippets, consider disabling them.
- Restart Obsidian
If it’s still broken:
- Try going back to the default theme to check if it’s an issue with the theme
- Enter restricted mode and restart Obsidian to check if it’s an issue with the theme.
Two major changes are:
- Instead of using Ctrl+Click (Cmd+click on macOS) to open links, you must now use Ctrl+Alt+Click (Cmd+Opt+Click on macOS)
- The hotkey to toggle task completion has changed: you can reset it in Settings → Hotkeys (search for “Toggle Checkbox Status”)
Thanks for the suggestions. I’ve tried all of those things, and the problem persists as I’ve described it. Very perplexing.
here’s the Debug info for the state with everything disabled:
Live preview: off
Legacy editor: on
Snippets enabled: 1
I am not sure I see anything wrong with this. Anyway.
Use the default theme, disable all snippets, enter restricted mode, restart obsidian. Post a screen recording of the graph view not working.
Again, I did all these things, and the problem persists. (Please see the screenshot). I even tried to reinstall Obsidian from scratch, and the problem STILL is there. I removed all the snippets, but the Debug still says there’s one installed. Is there a way to do a clean reinstall of the program, so that nothing from before is preserved? Thanks for your help with this frustrating problem. (None of the dots in the graph correspond to any of my note pages on the left)
What happens if you zoom in? How is your graph view configured?
Is it possible that you have search pre filled in place?
Can you go peek inside YourVault/.obsidian and see if you have any conflicted settings files? Do you store your vault in a cloud syncing tool?
If you have any sync-conflicted files, a setting might be getting stuck or something. Look for any files with numbers, or extra text (inside brackets) with a date.
Thank you for your help. I decided to delete everything (not my vault!) and start over. The graph view now functions normally, and the tedium of reinstalling plug-ins was worth it.
